i set up the media server an everything is fine. Only one but important thing does not work:
If i press rewind or forward, my tv says, that this is not possible.
My Samsung is a brand new UE46C6820.
Is there anys setting in the wild media server, that solves this problem?
boba
						Forward and rewind does not work
Re: Forward and rewind does not work
no possibility with some type of file, it's a persistant bug from samsung tv. I have the same issu with my UE40B7000 too
i tried yesterday mkv and avi. both didnt work. what file formats will work?
Hi there,
I played around a lot until I got my Samsung tv running right,tried alot of server programs out with different encoder settings.
WMS is the only one that works well for me including FF and RW.
I use Handbrake settings are:
Container-MKV
Web Optimized-ticked
Anamorphic-none
presets-Regular high profile(right hand window)
Audio window-I always use AAC all the other settings Auto except Bitrate 160
All other settings I leave as they are.
In WMS have a look in Settings-Device then on top line Type check that you have Samsung as device-Samsung TV (DLNA, 16:9, 1920x1080)
Hope this helps you out
Container-MKV
Anamorphic-none
i dont want to make advertisment for other companys, but i tried the twonky media server and with this i am able to forward and and rewind.
So i think its a missing feature of the wild media server....
						bobafett wrote: i set up the media server an everything is fine. Only one but important thing does not work:
Nothing concrete, an advertising and anti-advertisingbobafett wrote: i dont want to make advertisment for other companys, but i tried the twonky media server and with this i am able to forward and and rewind.
