Here is the URL:
mms://a120.l7085830119.c70858.g.lm.akamaistream.net/D/120/70858/v0001/reflector:30119
Clicking "Read properties from a file" shows that its 640x480 WMV.
However, a test transcode show the following:
Is there anything I can do please? Thanks in advance."C:\Program Files\Wild Media Server\wmsmpeg.exe" "C:\Program Files\VideoLAN\VLC\
vlc.exe" -Idummy --language=en --sout-ffmpeg-strict-rc --sout=#transcode{vcodec=
mp2v,vb=8000,fps=24,width=464,height=576,scale=1,vfilter=croppadd{paddleft=128,p
addright=128,paddtop=0,paddbottom=0},aspect=16:9,acodec=mpga,ab=192,channels=2,s
amplerate=48000}:duplicate{dst=std{access=file,mux=ps,dst="D:\WMS_TEMP\WmsTemp\T
est_a6fc072af1bed16aef67e7dce2c55ba0.mpg"}} "mms://a120.l7085830119.c70858.g.lm.
akamaistream.net/D/120/70858/v0001/reflector:30119"
[00bf0e64] dummy interface: VLC media player - version 1.0.5 Goldeneye - (c) 199
6-2010 the VideoLAN team
[00bf0e64] dummy interface: using the dummy interface module...
[00cac314] mux_ps mux: Open
[00cb06fc] access_mms access error: failed to open a connection (tcp)
[00cb06fc] access_mms access error: cannot connect to server
[00cb06fc] access_mms access error: cannot read data 2
