wmv files stop playing
all my wmv movie stop playing near 1 minute after begin. i update vlc to 1.05 version, i remove wmv from native playing file ( samsung le40b7000), and use Movies ( primary) to transcode them but nothing better, what's wrong?
Re: wmv files stop playing
Try transcoding profile "Movies - TsMuxer". May need to restore from a distribution Settings - Transcoder - Profiles - "Movies - TsMuxer" - Restorelecureuil wrote:all my wmv movie stop playing near 1 minute after begin. i update vlc to 1.05 version, i remove wmv from native playing file ( samsung le40b7000), and use Movies ( primary) to transcode them but nothing better, what's wrong?
i restore profil, and force to use tsmuxer for wmv files but i have the same issu: movie stop playing after 1 minute.
Settings-Transcoder-Codecs,frame-turn on "Limit min and max video bitrate".lecureuil wrote:i restore profil, and force to use tsmuxer for wmv files but i have the same issu: movie stop playing after 1 minute.
What a value of video bitrate ?
as you can see:
- transcode setting.JPG (83.04 KiB) Viewed 13920 times
I turn on limit the bit rate but the video stop after 1 minutes playing
Video bitrate: 6000000lecureuil wrote:I turn on limit the bit rate but the video stop after 1 minutes playing
not better: audio and video are not synchronised and now mp3 are playing to fast!
Re: all transcoding files stop playing
edit:
turn on limit and bit rate to 6000000 :video is playing until end of file, but i haven't sound!
i notice that for each transcoded movie i tri to play have the same issue ( wmv and flc tested)
