Hi Eugene. I was using 0.71, and it leaves vlc.exe open (shown in task manager) each time I quit watching a movie, resulting in multiple vlc.exe instances running at the same time. The instances doesn't go away unless I manually kill them with task manager or restart. I'm switching today to 0.72, I let you know if the problem persists.
Chris
VLC.exe not stopping
Re: VLC.exe not stopping
Hi, Chris,
Ok, I also check up.cgeorgakopoulos wrote:Hi Eugene. I was using 0.71, and it leaves vlc.exe open (shown in task manager) each time I quit watching a movie, resulting in multiple vlc.exe instances running at the same time. The instances doesn't go away unless I manually kill them with task manager or restart. I'm switching today to 0.72, I let you know if the problem persists.
