I have encountered an error using 1.00 when trying to transcode a mkv to my Samsung B650. The log is below. I copied the mkv to an external USB disk and managed to watch it on my TV so nothing seems to be wrong to the mkv itself, but something seems to make WMS to fail to transcode it.
"C:\Program Files\Wild Media Server\wmsmpeg.exe" -i "Z:\Video\test.mkv" -f mpegt
s -vcodec mpeg2video -b 20000000  -minrate 20000000 -maxrate 20000000 -bufsize 3
047424 -aspect 16:9 -copyts -pix_fmt yuv420p -s 1280x720 -vhook "wmssubt.dll Z:\
Video\test.mkv,Verdana,14,1,16777215,0,4,0,0,0,1280,720,23.976,0,0,0,[0x3],0,1"
-vhook "wmssubt.dll indicator,Verdana,14,1,16777215,0,4,1677721600,1280,720,35,4
,7" -threads 4 -acodec copy -map 0:0 -map 0:1 "F:\Transcode\WmsTemp\Test_fdbb388
50e57b311adec34366c712a8b.mpg" -v -1 -loglevel quiet
  built on May  2 2010 17:40:51 with gcc 4.4.0
  libavutil     50.13. 0 / 50.13. 0
  libavcodec    52.61. 0 / 52.61. 0
  libavformat   52.57. 1 / 52.57. 1
  libavdevice   52. 2. 0 / 52. 2. 0
  libswscale     0.10. 0 /  0.10. 0
  libpostproc   51. 2. 0 / 51. 2. 0
[matroska @ 003ca290]max_analyze_duration reached
[matroska @ 003ca290]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 23.98 (24000/1001)
Input #0, matroska, from 'Z:\Video\test.mkv':
  Duration: 02:13:51.07, start: 0.000000, bitrate: N/A
    Stream #0.0: Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 47.62 fps, 2
3.98 tbr, 1k tbn, 47.95 tbc
    Metadata:
      title           : By CMCT-hanksking
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 6 channels, s16
    Stream #0.2: Subtitle: 0x0000
    Metadata:
      title           : Þï▒õ©èõ©¡õ©ï
    Stream #0.3: Subtitle: 0x0000
    Metadata:
      title           : õ©¡õ©èÞï▒õ©ï
    Stream #0.4: Subtitle: 0x0000
    Metadata:
      title           : õ©¡µûç
    Stream #0.5: Subtitle: 0x0000
    Metadata:
      title           : Þï▒µûç
[matroska @ 025de160]max_analyze_duration reached
[matroska @ 025de160]Estimating duration from bitrate, this may be inaccurate
Output #0, mpegts, to 'F:\Transcode\WmsTemp\Test_fdbb38850e57b311adec34366c712a8
b.mpg':
: Video: mpeg2video, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], q=2-31, 20000 kb/s, 9
0k tbn, 23.98 tbc
Stream mapping:
  Stream #0.0 -> #0.0
  Stream #0.1 -> #0.1
Press [q] to stop encoding
av_interleaved_write_frame(): Error number -1 occurred
						Error number -1 occured in transcoding
Re: Error number -1 occured in transcoding
Settings-Transcoder-"Codecs, frame" - turn off "The original sound track, if the compression is the same".copson wrote:I have encountered an error using 1.00 when trying to transcode a mkv to my Samsung B650. The log is below. I copied the mkv to an external USB disk and managed to watch it on my TV so nothing seems to be wrong to the mkv itself, but something seems to make WMS to fail to transcode it.
Metadata:
Metadata:
Metadata:
Metadata:
title : õ©¡µûç
Metadata:
title : Þï▒µûç
b.mpg':
0k tbn, 23.98 tbc
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Thanks, it worked perfect after turning that setting off!Settings-Transcoder-"Codecs, frame" - turn off "The original sound track, if the compression is the same".
