Internet television - setup
sony40w5500
Post by sony40w5500 »
Hi Eugene!
Your program is very good!
I just tried to set up a tv online stream. But I couldn't play anything on my Sony 40W5500.
Now I can listening to online radios on my television, but no web TV-s.
Could you please show an example, how to set up in the program an on-line TV broadcast?
tomas
Re: Internet television - setup
Post by tomas »
Hi sony40w5500!
Can you advice me please how to add online radio to WMS ?
sony40w5500
tomas wrote:Hi sony40w5500!
Hi Tomas!
Just click on Music button, then choose Internet Radio on the left.
Then click right mouse button on the right side, choose Add link.
To "Path" line write the radio link, for example: http://radiator.nci.de:8000/high_q
Read properties from file button and OK.
Now you'll see the radio channel on your TV in the music section, Internet Radio!
sony40w5500 wrote: Your program is very good!
1. Verify that the link VLC plays.
2. In program activate the section Internet TV.
3. In the list of films on right click "mouse" - Add link, in the Path field to specify a link - OK.
4. Settings - Transcoder - Profiles - "Internet-television" - Edit, find the line 'mpeg1' and replaced by 'ps' - OK - OK - OK.
5. In the list of films on right click "mouse" to implement the transcoding test, make sure that there are no errors. If the setup program's on the page Transcoder specified directory, you can check transcoded file and increase its size.
6. Run the play on TV.
sony40w5500
Thanks!!!
It works!!! Great! ;)
rc4991
Post by rc4991 »
I am also trying to get internet tv to work. I tried to follow your directions, but am confused.
I have VLC. I added the link. But I can not find where to edit the transcoding profile.
I go to settings - transcoder. From here I can select a profile for internet TV, but not to edit.
I'm then not able to find the mpeg1 reference which you suggest needs to change to ps.
Can you clarify this step?
rc4991 wrote:I am also trying to get internet tv to work. I tried to follow your directions, but am confused.
Button Profiles
rc4991
Post by rc4991 »
Screen shot please.
rc4991 wrote:Screen shot please.
mikek
Post by mikek »
Any chance someone could post more detailed instructions on how to set a link to Internet TV. I get most of what is being said but like others still need some help.
I would be great if there was a Guide section where this sort of stuff was posted
thanks Mike
