No audio
nickir
No audio
Post by nickir »
I have tried to share a file from WMS, to my Sony EX500, and my PS3. And on both there are no audio. The file is a AVCHD, and the audio is DTS. On any other file there is no problem with other files.
Is there some way, to get the audio, it dosen't have to be DTS, but off cause it cut be awesome.
Does anyone have an idea or solution.
Re: No audio
nickir wrote:I have tried to share a file from WMS, to my Sony EX500, and my PS3. And on both there are no audio. The file is a AVCHD, and the audio is DTS. On any other file there is no problem with other files.
Choose playing via a folder Transcoding
nickir
Re: No audio
Post by nickir »
what folder transcoding is that.?
Im pretty new on this.. :(
Re: No audio
nickir wrote:what folder transcoding is that.?
The same folder should be on a media device
nickir
Re: No audio
Post by nickir »
Okay.. Thank you..
I works now. I don't know how, it just works..
But now, some of the big files (over 9 or 10 GB) its lagging when I play it. Is it the computers performance.? If i pause it a bit, it's okay for a while, but then it start again. What can it be?
Re: No audio
nickir wrote:Okay.. Thank you..
If the video encoding is supported by TV, then you can use the transcoding profile "Movies - TsMuxer" (video is not transcoded). Settings - "File Types" - m2ts
nickir
Re: No audio
Post by nickir »
I found it. And it works. Thank you very much.
But can you do it with a mkv file for example..? So the picture wont lag?
