Suggestions to reduce CPU usage.
Posted: Thu Jan 14, 2010 2:41 pm
by gaingi
this program is Great. But with a processor like IntelĀ® Atom 320 (1,6 Ghz), it takes 100% of the CPU usage (when trascoding). So, if my wife watch a movie, I can not read a mail...
Do you have any suggestion to configure WMS to reduce CPU usage?
Thank you.
Re: Suggestions to reduce CPU usage.
Posted: Thu Jan 14, 2010 5:06 pm
gaingi wrote:Hi Eugene,
Thank you.
To reduce CPU usage can be used:
1. Reduce the size of the frame.
2. Enable change of the original frame size "Minimum, proportional to the screen" and select the supported frame size.
- transcoder2.JPG (83.55 KiB) Viewed 9544 times
3. Change the priority of performance transcoding.
- transcoder1.JPG (80.7 KiB) Viewed 9544 times
4. Use (if possible device) remuxing transcoding profiles (Movies-TsMuxer, Movies-WMF) instead of the full profile transcoding. If supported CUDA, you can use the profile transcoding Movies - CoreAVC.
Think netbook ill-suited for transcoding on the fly, probably a very heated
