Suggestions to reduce CPU usage.
gaingi
Post by gaingi »
this program is Great. But with a processor like Intel® Atom 320 (1,6 Ghz), it takes 100% of the CPU usage (when trascoding). So, if my wife watch a movie, I can not read a mail...
Do you have any suggestion to configure WMS to reduce CPU usage?
Thank you.
Re: Suggestions to reduce CPU usage.
gaingi wrote:Hi Eugene,
Thank you.
To reduce CPU usage can be used:
1. Reduce the size of the frame.
2. Enable change of the original frame size "Minimum, proportional to the screen" and select the supported frame size.
3. Change the priority of performance transcoding.
4. Use (if possible device) remuxing transcoding profiles (Movies-TsMuxer, Movies-WMF) instead of the full profile transcoding. If supported CUDA, you can use the profile transcoding Movies - CoreAVC.
Think netbook ill-suited for transcoding on the fly, probably a very heated
