I have a series of good quality mkv's that play just fine over a CIFS share. But as soon as I try to stream them my media player reports an incorrect file size, stalls, and cannot FF or RW.
I have WMS installed on a WHS, using a WDTV Live for playback.
As I said, on my PC or on the WDTV Live over a CIFS share playback is perfect.
But streaming over WMS (no transcoding) playback is poor.
I think the problem may be with the encoding,  the movies use: V_MPEG4/ISO/AVC
Here is the output from MediaInfo:
-Any suggestions?
Do I need to remux or re-encode the movies? I do not want to transcode with WMS...
Complete name                    : H:\The.Bourne.Ultimatum.2007.Bluray.1080p.DTS.mkv
Format                           : Matroska
File size                        : 12.6 GiB
Duration                         : 1h 55mn
Overall bit rate                 : 15.6 Mbps
Encoded date                     : UTC 2010-01-22 03:03:58
Writing application              : mkvmerge v3.0.0 ('Hang up your Hang-Ups') built on Dec 12 2009 15:20:35
Writing library                  : libebml v0.7.9 + libmatroska v0.8.1
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Muxing mode                      : Container profile=Unknown@4.1
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1h 55mn
Bit rate                         : 13.2 Mbps
Nominal bit rate                 : 13.6 Mbps
Width                            : 1 920 pixels
Height                           : 800 pixels
Display aspect ratio             : 2.40:1
Frame rate                       : 23.976 fps
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.360
Stream size                      : 10.7 GiB (85%)
Title                            : The.Bourne.Ultimatum.2007.Bluray.1080p.DTS.3Audio.x264-CHD
Writing library                  : x264 core 83 r1391 3d0f110
Encoding settings                : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.2:0.1 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=2 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=13564 / ratetol=1.0 / qcomp=0.65 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=50000 / vbv_bufsize=50000 / ip_ratio=1.40 / aq=2:0.90
Language                         : English
Audio #1
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 1h 55mn
Bit rate mode                    : Constant
Bit rate                         : 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Sampling rate                    : 48.0 KHz
Resolution                       : 24 bits
Stream size                      : 1.22 GiB (10%)
Title                            : DTSHDMA Core 5.1 1536K
Language                         : English
Audio #2
Format                           : AC-3
Format/Info                      : Audio Coding 3
Codec ID                         : A_AC3
Duration                         : 1h 55mn
Bit rate                         : 384 Kbps
Video delay                      : 1s 0ms
Stream size                      : 317 MiB (2%)
Title                            : DD5.1 384k 国语
Language                         : Chinese
Audio #3
Format                           : AC-3
Format profile                   : Dolby Digital
Codec ID                         : A_AC3
Duration                         : 1h 55mn
Bit rate                         : 192 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Stream size                      : 158 MiB (1%)
Title                            : DD2.0 192K commentary/导演评论
Language                         : English
BR
							Strange Behaviour with MKV [V_MPEG4/ISO/AVC]
Wild Media Server installed on: Windows Home Server (3Tb custom build)
Playback on: WDTV-Live via Yamaha RXV-1800 Receiver
Viewing on: 46" Samsung 6-Series LCD
Re: Strange Behaviour with MKV [V_MPEG4/ISO/AVC]
WMS is a server, not the player. If you do not use transcoding, there is no reason for a poor quality, only better (transfer speed).brettich wrote:I have a series of good quality mkv's that play just fine over a CIFS share. But as soon as I try to stream them my media player reports an incorrect file size, stalls, and cannot FF or RW.
I fully understand that WMS is the server.
What I tried to say: The movie I posted the Mediainfo from, plays BETTER if it is not served over WMS
For some reason this movie and (two others encoded just like it) play better from a share than from the WMS.
All my other moves play (via WMS) perfectly
Since I want all my movies served by WMS, I though you might be interested in a possible "bug" with this particular format?
BR
BR
You have enabled showing the transcoding panel ?brettich wrote:I fully understand that WMS is the server.
