Video Watch folder skipping ISO
davel
Post by davel »
My video watch folder is seems to be working for everything other than ISO files. ISO files are discovered at server restart but not after.
Sorry if this has been covered elsewhere, my search kept getting rejected because it was too short. ;)
Currently using 73.8 from 4/27. but started to notice before that.
1x WDTV Live (FW 1.01.24)
1x O!Play HDP-R1 FW 1.18N
2x SMCWAA-G EZ Stream (never updated)
1x Dlink DSM-520 Media Lounge (FW 1.06 ,replaced by the WDTV Live)
Re: Video Watch folder skipping ISO
davel wrote:My video watch folder is seems to be working for everything other than ISO files. ISO files are discovered at server restart but not after.
ISO-files are available in a folder "CD/DVD/BD Images (ISO)"
davel
Post by davel »
Understand, but I'm only seeing new ones when I full restart, scanning stop start of server does nothing with the iso. Only when I totally shut down / quit the server and restart does it see the new iso files. avi files so far don't seemed affected.
davel wrote:Understand, but I'm only seeing new ones when I full restart, scanning stop start of server does nothing with the iso. Only when I totally shut down / quit the server and restart does it see the new iso files. avi files so far don't seemed affected.
Try to describe the sequence (1, 2, 3, ...) your actions and expected results. I have no problems with ISO-files.
davel
Post by davel »
Ok lets see if I can show this. ** Again, problem is not with playing iso, but getting it to show up in a watch folder.** Not really doing much other than move the iso into watch folder, then have to "quit" WMS and restart it. Hope this helps. Not really a show stopper since I know how to work around it. The times have no dates listed, one might think they are reversed. but its not. guess I just restarted it about the same time as last time, but windows time and date in lower right are correct.
Showing current watch folder contents, avi files above with iso files listed in the iso folder.
Before doing anything
Copied TRUE.BLOOD.S01.D02.NAR.NDT.iso into the watch folder, but WMS still has not detected it.
after moving trueblood disk 2 to the watch folder.  WMS still has not detected it, nor will it with a stop and restart
stop,shutdown and quit of WMS, then reload. Now TRUE.BLOOD.S01.D02.NAR.NDT.iso is visible in the iso folder list
After a total shutdown "quit" of the WMS server, now the desk 2 of trueblood is showing up...
davel wrote:Ok lets see if I can show this. ** Again, problem is not with playing iso, but getting it to show up in a watch folder.** Not really doing much other than move the iso into watch folder, then have to "quit" WMS and restart it. Hope this helps. Not really a show stopper since I know how to work around it. The times have no dates listed, one might think they are reversed. but its not. guess I just restarted it about the same time as last time, but windows time and date in lower right are correct.
My sequence (iso folder ADVD)
1. Start WMS.
2. Move album.iso to ADVD.
3. Settings-button Scanning - OK - album.iso in CD/DVD/BD Images.
4. Quit WMS.
5. Move album.iso to temp folder.
6. Start WMS.
7. Settings-page Scanning - turn on "Automatically scan directories..." - OK
8. Start Server
9. Move album.iso to ADVD.
10. Album.iso in CD/DVD/BD Images.
