In an attempt to fix fast forward on my TV I changed a few settings. Now FF works, but instead of being able to open the video right from the "All Movies" folder, I get a folder called "(T) <filename>", and inside that folder is a "(T) Interval 10 minutes <filename>", and then the actual file I can open to play below that. And below that again, stuff like "(T) Settings", "(T) Add to favorites".
How can I return to getting simply a list of my video files directly under "All Movies"?
By the way, this application is great! I have only tried it briefly, and it plays everything perfectly (once I figured out how to fix Fast Forward, and enable Chunked Transfer Mode so that it could play the last few second). It has handled everything I've thrown at it so far.
So kudos to the developers for a great application. I will definitely keep using it!
