Sony 55EX505 - Transcoding Aspect Ratio
naja
Post by naja »
Hi
I've been searching this forum for a while but all I found didn't help - or probably - I did something wrong.
When I'm streaming my file to the tv the picture is displayed correctly, but my tv doesnt support the sound format so i have to do transcoding.
When I do transcoding the sound is working but I got some problems with the picture. Aspect ratio is stretched (additional bars above and below the video). Transcoding setting: Movies (primary)
So I tried to set the Viodeo options to original but this does not work.
I tried several things in Transcoder -> Codec, frame because I thought that the bars have something to do with the "Active pad color" thing, but no change.
If anyone has an idea what to do help me please :)
Re: Sony 55EX505 - Transcoding Aspect Ratio
Perhaps you are using custom settings media device ? (Settings-Server-A list of allowed client devices)
naja
Post by naja »
my settings are in both lists: allowed all
Media device type is: Sony TV (DLNA, 16:9, 1920x1080)
Right-click the you can perform test transcoding, if in call parameters is padleft, padcolor, then padding by color turned on.
naja
Post by naja »
the "pad" parameters are not there
i played with the settings an the parameteres appeared but no change
naja wrote:the "pad" parameters are not there
Perhaps it should be. The bars in the original video or so played TV.
naja
Post by naja »
I tried to paint a picture of what I get.
left: the original movie how it should look like. thats also what I get when i do playback without transcoding
right: thats how it looks when I do transcoding
I don't understand where these additional bars come from.
naja wrote:I tried to paint a picture of what I get.
If the original frame of 16:9 is placed in frame of 4:3, then the information about the film select Frame DVD 16:9
naja
Post by naja »
Transcoder > Frame Size (unit pixels) > Format 4:3
fixed my problems
vol88
Post by vol88 »
I have a Sony Bravia 40EX505 and I was also scratching my head over this one. The 4:3 workaround also works for me. I have also chosen “Sony TV (DLNA, 16:9, 1920x1080)” as Media Device.
I did some tests with a few movie trailers and found the following behavior.
Under “Transcoder” → “Codecs, frame” → “Frame size” I set:
16:9 and "Active pad color" checked → aspect ratio on the Sony TV always wrong
4:3 and "Active pad color" checked → aspect ratio on the Sony TV always correct (at least for all the videos I've tried)
16:9 and "Active pad color" unchecked → aspect ratio on the Sony TV always wrong
4:3 and "Active pad color" unchecked → aspect ratio on the Sony TV is correct for some videos, but wrong for some others
It doesn't make sense, but I am happy there is at least one setting that seems to work. :-)
