Comedy Central (http://www.cc.com/)
Comedy Central (http://www.cc.com/) - required version 1.79
comedycentral.zip
(7.51 KiB) Downloaded 1516 times
2. Drag and drop comedycentral.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Comedy Central". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file comedycentral.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "Comedy Central", you can create first level of Comedy Central navigation.
Additional parameters - select the folder "Comedy Central" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Video count per folder (by default 15):
--videocount=NN
Maximum video height:
--maxheight=NNN
Subtitles support:
--subtitles=on
Subtitles language:
--sublanguage=en
samsungfan
Re: Comedy Central (http://www.cc.com/)
Post by samsungfan »
This is not working anymore
