NBC - Shows (http://www.nbc.com/video/)
NBC - Shows (http://www.nbc.com/video/) - required version 1.77
nbc_shows.zip
(6.22 KiB) Downloaded 1587 times
2. Drag and drop nbc_shows.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "NBC - Shows". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file nbc_shows.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "NBC - Shows", you can create first level of "NBC - Shows" navigation.
Additional parameters - select the folder "NBC - Shows" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Maximum bitrate (by default 3000 kbit/s):
--maxbitrate=NNNN
Subtitles support:
--subtitles=on
Video count per page (by default 25):
--videocount=NN
Maximum video height:
--maxheight=NNN
Updated 2014/03/07
Re: NBC - Shows (http://www.nbc.com/video/)
Updated 2014/03/07
