Australian Channel One (http://one.com.au/)
Locked
Australian Channel One (http://one.com.au/) - required version 1.77
au_one.zip
(4 KiB) Downloaded 1521 times
2. Drag and drop au_one.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Australian Channel One". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file au_one.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "Australian Channel One", you can create or update first level of Australian Channel One.
Additional parameters - select the folder "Australian Channel One" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Video count (by default 50):
--videocount=NN
Re: Australian Channel One (http://one.com.au/)
Locked
