RTE Player (http://www.rte.ie/player/)
RTE Player (http://www.rte.ie/player/) - required version 1.77
rteplayer.zip
(4.89 KiB) Downloaded 918 times
2. Drag and drop rteplayer.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "RTE Player". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file rteplayer.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "RTE Player", you can create or update first level of RTE Player navigation.
Additional parameters - select the folder "RTE Player" - right click - Edit title/settings - Transfer - Additional parameters
Video count (by default 50) for the folder Latest:
--videocount=NN
