RTL XL (http://www.rtl.nl/xl/)
RTL XL (http://www.rtl.nl/xl/) - required version 1.77
rtl xl.zip
(3.15 KiB) Downloaded 860 times
2. Drag and drop rtl xl.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "RTL XL". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file rtl xl.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "RTL XL", you can create or update first level of RTL XL navigation.
Additional parameters - select the folder "RTL XL" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
