SVT Play (http://www.svtplay.se)
SVT Play (http://www.svtplay.se) - required version 1.77
svtplay.zip
(5.34 KiB) Downloaded 828 times
2. Drag and drop svtplay.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "SVT Play". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file svtplay.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "SVT Play", you can create or update first level of SVT Play navigation.
Additional parameters - select the folder "SVT Play" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
:!: Service only available in the Sweden :!:
