PBSKids (http://pbskids.org/go/video/)
PBSKids (http://pbskids.org/go/video/) - required version 1.77
pbskids.zip
(7.12 KiB) Downloaded 846 times
2. Drag and drop pbskids.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "PBSKids". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file pbskids.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "PBSKids", you can update the list of podcasts.
Subtitles support: select the folder "PBSKids" - Edit title/settings - Transfer - "Additional parameters" -
--subtitles=on
Video count (by default 50): select the folder "PBSKids" or subfolder - Edit title/settings - Transfer - "Additional parameters" -
--videocount=NNN
:!: Service only available in the United States :!:
