Hulu Desktop (http://www.hulu.com)
Hulu Desktop (http://www.hulu.com) - required version 1.77
huludesktop.zip
(8.25 KiB) Downloaded 1586 times
2. Drag and drop huludesktop.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Hulu Desktop". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file huludesktop.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "Hulu Desktop", you can create first level of Hulu Desktop navigation.
:!: Service only available in the United States :!:
Hulu login: select the folder "Hulu Desktop" - right click - Edit title/settings - Connection - Authorization - On - UserName: your Hulu login, Password: your Hulu password
Additional parameters: select the folder "Hulu Desktop" - right click - Edit title/settings - Transfer - Additional parameters:
--subtitles=on | off (subtitles suport)
--mutibitrate=on | off (create video links with various bitrates)
--videotype=on | off (adds a video type (clip, episode, ...) to title of media-resource
samsungfan
Re: Hulu Desktop (http://www.hulu.com)
Post by samsungfan »
This is not working.
