I am using the XBOX (in Media Center Extender Mode) as a Renderer. Works fine together with the Wild Media Server. However, when I try to send podcast links directly to the XBOX, this does not work.
When I check the UPnP messages on the network, I see that after the SetAVTransportURI is sent, the XBOX returns an error:
ERROR_AV_UPNP_AVT_RESOURCE_NOT_FOUND
This is error message 716 from Microsoft, it means: The specified resource cannot be located on the network.
Is there a way to fix this?
JEEVO
