Released version "Wild Media Server (DLNA) v1.54.1 (32-bit)
Locked
Update to 1.54
Wild Media Server (UPnP, DLNA, HTTP) v.1.54
1. Added support for iso-images of SACD-discs and dff-files (DSD and DST-encoding)
2. Added the transcoding module for SACD-files (http://sacddecoder.sourceforge.net/).
3. Added the transcoding profile "Music - SACD".
4. Individual settings of the client device - Transcoder - "Files, subtitles" - "Transcoding file parameters" - Music:
  • added configuration settings for maximum LPCM-transcoding parameters (Sample rate, Channels, Bits (size of sample), by default 44100, 2, 16), used for the transcoded file formats s16be, wav.
5. Updated the transcoding profiles "Music - FLAC", "Music - APE", "Music - WAVPACK", "Music - DVD-Audio", changes for support maximum LPCM-transcoding parameters (if the transcoding profiles changed, it is recommended to restore the profiles from the distribution kit).
6. The main form of the program:
  • in the track list of video files added the columns "Codec (profile)", "Codec (level)", "ReFrames", added reading the specified parameters at loading file properties, can be used to configure "Additional verification of support files".
Update to 1.54.1
1. Added device configurations:
  • "Oppo Player (DLNA, 16:9, 720x406)";
  • "Sony Network Media Player (DLNA, 16:9, 720x406)".
2. Added support for bookmarks on the media resources folders through navigation on the media device (in the bottom of the list of media resources is added the folder "Add Bookmark"), this feature can be off in the settings of the program (Settings - "Media-Resources" - Service - Folder "Bookmarks").
3. To the structure of the media resources added the folder "Bookmarks" and "Last Browse" (for each client device they own). In the folder "Last Browse" added links to the most distant folders that were selected in the process of the media device navigation. The folder "Last Browse" can be used to continue navigation, if the number of levels of navigation on the media device is limited.
4. Added ability to restrict access of client devices to media resources by rating in stars and the color system parental control (http://en.wikipedia.org/wiki/Motion_pic ... ing_system), can be used separately or together.
5. The main form of the program:
  • to the list of movies, music, photos added the column "Rating in stars" (set by using the "mouse"), "Parental Control" (the choice of values ​​from the context menu), setting the values ​​for the folder and all child items with pressing Shift.
6. Information about the client device:
  • added setting "The minimum rating in stars of media resources" and color system "Parental Control" (maximum value).
7. Settings - "Media-resources":
  • added the button "Parental control by default" (on the right of folder "My Computer") to call the form "Settings the parental control and rating in stars of media resources".
8. Settings - Devices:
  • added the button "Parental control by default" (in the settings of new devices) to call the form "Settings the parental control and rating in stars of media resources".
9. Settings - "Media-resources" - Service:
  • added the settings page for the folder "Bookmarks";
  • added settings to restrict access to folders "Transcoding" and "Sort Order" (using this setting, the folder can be turned off for individual client devices).
10. Added the properties of media resources:
  • mpAddDate - date of adding a media resource to the media database;
  • mpLastPlaybackTime - date of the last play of media resource;
can be used in scripts processing, grouping of media resources.
Re: Released version "Wild Media Server (DLNA) v1.54 (32-bit
sonynmp_2012_dlna_wide_720x406.zip
(3.92 KiB) Downloaded 1049 times
2. Copy sonynmp_2012_dlna_wide_720x406.cfg to ?:\Program Files (x86)\Wild Media Server\Devices
3. Restart the program
4. Settings - Devices - choose a device - Type - "Sony Network Media Player (DLNA, 16:9, 720x406)"
Sony Network Media Player SMP-N200 (probably SMP-N100)
oppo_player_dlna_720x406.zip
(3.53 KiB) Downloaded 1053 times
2. Copy oppo_player_dlna_720x406.cfg to ?:\Program Files (x86)\Wild Media Server\Devices
4. Settings - Devices - choose a device - Type - "Oppo Player (DLNA, 16:9, 720x406)"
Oppo BDP-83, Oppo BDP-93, Oppo BDP-95
LPCM Transcoding (Sample Rate: 192000, Channels: 6, Bits Per Sample: 16)
P.S. Required version WMS 1.54
Re: Released version "Wild Media Server (DLNA) v1.54.1 (32-b
Update to 1.54.1
Locked
