DTS Audio
gtp_98c
DTS Audio
Post by gtp_98c »
I have a few movies that have DTS on them. When i play them with PS3 Media server i get the good DTS audio, when i play the same movie via transcode or not i do not get DTS... Ideas? I just downloaded and installed this product yesterday.. Did some searching and found nothing thus far.
Thx
Re: DTS Audio
gtp_98c wrote:I have a few movies that have DTS on them. When i play them with PS3 Media server i get the good DTS audio, when i play the same movie via transcode or not i do not get DTS... Ideas? I just downloaded and installed this product yesterday.. Did some searching and found nothing thus far.
Thx
If your device understands DTS Audio, why do you transcoding?
gtp_98c
Re: DTS Audio
Post by gtp_98c »
The only reason i chose the transcode option is cause i wasn't seeing DTS on either the XMB or my reciever even though i have my audio settings set to Linear PCM rather than Bitstream on my PS3. Should i not see DTS on one or the other during playback which would indicate it is playing DTS?
Thx
Re: DTS Audio
gtp_98c wrote:The only reason i chose the transcode option is cause i wasn't seeing DTS on either the XMB or my reciever even though i have my audio settings set to Linear PCM rather than Bitstream on my PS3. Should i not see DTS on one or the other during playback which would indicate it is playing DTS?
Thx
Sorry, I do not understand what the problem is, there is no sound on the playback device ?
gtp_98c
Re: DTS Audio
Post by gtp_98c »
Ok, i have one movie - Transformers Revenge of the Fallen. When i play it on my PS3 using PS3 Media Server i get Dolby Digital 5.1 showing up on the info screen of the PS3 that you get by hitting the triangle. When i play the same movie with WMS it shows 2 ch Dolby Digital and it sounds awful... How do i get it the same with WMS? In addition to that i have Valkyrie which is M2TS as well and has DTS, with PS3 Media server i show DTS on the screen of the XMB info with WMS i do not. I assume i am missing an setting or something somewhere.
Re: DTS Audio
gtp_98c wrote:Ok, i have one movie - Transformers Revenge of the Fallen. When i play it on my PS3 using PS3 Media Server i get Dolby Digital 5.1 showing up on the info screen of the PS3 that you get by hitting the triangle. When i play the same movie with WMS it shows 2 ch Dolby Digital and it sounds awful... How do i get it the same with WMS? In addition to that i have Valkyrie which is M2TS as well and has DTS, with PS3 Media server i show DTS on the screen of the XMB info with WMS i do not. I assume i am missing an setting or something somewhere.
PS3 does not support DTS via DLNA or there is some new firmware PS3 ? How the quantity channels in the list of films for the "Transformers Revenge of the Fallen" ?
gtp_98c
Re: DTS Audio
Post by gtp_98c »
Yes, it supports DTS, it does not support the new HD ones (DTS-MA and True HD). The movie has DTS 5.1 @ 1509 kbps when i do a properties of the audio file for the movie in WMS.
Re: DTS Audio
gtp_98c wrote:Yes, it supports DTS, it does not support the new HD ones (DTS-MA and True HD). The movie has DTS 5.1 @ 1509 kbps when i do a properties of the audio file for the movie in WMS.
On the PS3 there is no sound
gtp_98c
Re: DTS Audio
Post by gtp_98c »
Well did you go thru the transcode folder?
Re: DTS Audio
gtp_98c wrote:Well did you go thru the transcode folder?
No problem, Dolby Digital 5.1
