Released version "Wild Media Server (DLNA) v1.52.3 (64-bit)
Locked
Update to 1.52.2
Wild Media Server (UPnP, DLNA, HTTP) v.1.52
1. The main form of the program:
  • added panels of buttons, that duplicate context menus of structure and list of media resources;
  • to panels of structure of media resources added the column "Sort Order";
  • to list of movies added the columns "Series Name", "Season No", "Episode No", "Episode Name", can be filled with loading information
    from online database of series.
2. Loading data from online database of movies, music:
  • added the mode "Automatic loading information" (available, if the settings of the database have a script that generates tabular results);
  • added the possibility of converting search keywords by using Google Transliteration;
  • added navigation buttons for the current list of media resources;
  • added scripts for IMDb Germany (IMDB.DE), IMDb France (IMDB.FR), IMDb Italy (IMDB.IT), IMDb Spain (IMDB.ES), IMDb Portugal (IMDB.PT).
3. Navigation on the media device:
  • added the folder "Sort" - choice sort of media resources in the current folder of media resources and child folders of media resources
    (disabling the folder in settings of the program). After choosing the sort need to move from the current folder to generate a list media
    resources in the selected sort order, you may need restart the server or device, if the device caches a list of media resources.
4. Settings - Media-Resources:
  • in the "Folder list" added the column "Exclude hidden files, directories";
  • to page "Service" added settings of folder "Sort order" - the choice of fields to sort, when you navigate on the media device.
5. Editing information about the folder of media resources:
  • added the field "Sort order".
Update to version 1.52.3
1. Added support for transcoding music with visualization modules. Supported types of visualization modules: Windows Media Player, Winamp, BassBox, Sonique. Working capacity the modules may depend on computer graphics system.
2. Folder "Movies":
  • Added folder "Music (Visualization)". Through the navigating on the media device, you can select the active visualization module or turn on the random selection of visualization module.
3. The main form of the program:
  • in the status bar added the button "List of music visualization modules" (configure of modules, choose the default module).
4. Individual settings of the client device - Additional:
  • added settings of music visualization.
5. Added the transcoding profile "Music (Visualization)".
6. Added device configurations:
  • "Samsung TV [E] (DLNA, 16:9, 720x406)";
  • "Sony BDP 2012 (DLNA, 16:9, 720x406)";
7. Individual settings of the client device - Transcoder - "Files, subtitles" - "Transcoding file parameters" - Padding - Suffix:
  • you can specify a negative value, in this case the padding of transcoded file will occur until the end of play media resource (determined by the duration of a media resource) + specified value (absolute).
Music (Visualization) on your DLNA, UPnP devices
New version wmssfx.exe (Visualization module) for 1.52.3 - fixed possible problem with uncompleted video
Unzip, copy wmssfx.exe to ?:\Program Files (x86)\Wild Media Server
Re: Released version "Wild Media Server (UPnP) v1.52.2 (64-b
Update to 1.52.2
1. Loading data from online database of movies, music:
  • added scripts for IMDb Germany (IMDB.DE), IMDb France (IMDB.FR), IMDb Italy (IMDB.IT), IMDb Spain (IMDB.ES), IMDb Portugal (IMDB.PT);
  • updated script for IMDB.COM (support for tabular results).
P.S. If the scripts are changed by the user, the new versions can be loaded from "?:\Program Files (x86)\Wild Media Server\wmsimdb.cfg"
Re: Released version "Wild Media Server (UPnP) v1.52.3 (64-b
2. Folder "Movies":
  • "Sony BDP 2012 (DLNA, 16:9, 720x406)".
DAVIDF wrote:6. Added device configurations:
does not show in the device list after upgrade
Thanks for your message.
Temporary fix.
samsung_e_dlna_16x9_720x406.zip
(3.69 KiB) Downloaded 1130 times
Unzip, copy samsung_e_dlna_16x9_720x406.cfg to ?:\Program Files (x86)\Wild Media Server\Devices, restart the program.
Locked
