Panasonic line G20: smooth transcode 23.97 and 25 FPS
Help other users and get free licenses Wild Media Server (UPnP, DLNA, HTTP)
fleggy
Post by fleggy »
I've prepared modified profile Movies (additional)_FR which correctly transcodes both framerates. It means smooth and in sync (audio, video).
Go to:
- Settings, Transcoder, click the button Profiles
- find Movies (additional) in the Trancode profile list
- select it and click Copy
- find Movies (additional)_1 and click Edit
- rename profile to Movies (additional)_FR or anything else you like
- overwrite the body with the attached file Movies (additional)_FR.txt
- click ok, ok (now you are back in the main setting window)
- click Devices, select your tv, click Settings
- click Files, subtitles
- select your new Transcoding profile (Movies (additional)_FR in my case)
- click ok, ok and enjoy :)
BR
Tomas
Movies (additional)_FR.zip
(1.79 KiB) Downloaded 1752 times
fleggy
Re: Panasonic line G20: smooth transcode 23.97 and 25 FPS
Post by fleggy »
after a few recent WMS updates my modification has stopped work. Here is the actual version of my transcode profile Movies (additional)_FR. The difference between this one and the standard one is very small because the modification was partially adapted by author but 23.97 movies are still not smooth with the standard one.
BR, Tomas
Movies (additional)_FR_NEW.zip
(2.08 KiB) Downloaded 1559 times
