I've started having trouble pre-transcoding files. The process I'm using is to backup my dvd with DVDfab, then create a single MPG file using VOB2MPG. This file is then fed into WMS and pre-transcoded using shift 5 on the file. The parameters I'm using are - MPEGTS container and the Movies (primary) Transcoding profile, mpg file extension and MIME-type video/mpeg.
The problems I'm having are that on play back the audio breaks up at the start and the pre-transcoded file is 2/3rds the size of the original.
Any ideas?
						Pre-transcoding
Re: Pre-transcoding
DVD can be protected, encrypted. Checked playback of the source file on your computer?maybury wrote: I've started having trouble pre-transcoding files. The process I'm using is to backup my dvd with DVDfab, then create a single MPG file using VOB2MPG. This file is then fed into WMS and pre-transcoded using shift 5 on the file. The parameters I'm using are - MPEGTS container and the Movies (primary) Transcoding profile, mpg file extension and MIME-type video/mpeg.
Re: Pre-transcoding
DVD is not encrypted and source file plays OK if I copy it to an external drive and directly connect it to the Samsung.
Re: Pre-transcoding
With TsMuxerGUI can change the format to ts or m2ts.maybury wrote: DVD is not encrypted and source file plays OK if I copy it to an external drive and directly connect it to the Samsung.
Re: Pre-transcoding
Tried both options but audio still breaks up. Dynamically transcoding the source file works but the video stops after 15 minutes as before. I am using the MPEGTS file format container.
Re: Pre-transcoding
The problem for all files or specific? There was a similar problem on the Samsung, playback stopped in jumpstarting values videobitrate (scene change). But there it was on the bitrate close to 20 MBit.maybury wrote:
Re: Pre-transcoding
Seems to be all files.
Re: Pre-transcoding
If you are using a connection through a router, then try to connect directly to TV and computer.maybury wrote: Seems to be all files.
Re: Pre-transcoding
Not sure if it's router problem as I can play a pre-transcoded file all the way through even though the audio breaks up at the start.
Re: Pre-transcoding
If playback all the files stops after 15 minutes, then check the direct connection.maybury wrote: Not sure if it's router problem as I can play a pre-transcoded file all the way through even though the audio breaks up at the start.
