Settings - Devices - choose a device - Settings - check the settingsArthur Dent wrote:
I have a Toshiba Regza TV and use 'Toshiba - WX800U (DLNA, 16:9, 1920x1080)' as base setting.
The Transcoder is set to File Format: MPEG (DVD), Codec: MPEG2. No other settings work with that TV.
In the "Support for files without transcoding" section I entered a '*' for Movies.
The problem is: Alle movie types play without problem on the TV: FLV, MOV, AVI, WMV. But not MPG.
For MPG my TV displays an error. When I look into the temporary files directory, I see a file appearing whenever I play a movie.
But not for MPG. It seems that MPG files are sent directly to TV without transcoding.
Does anybody have an idea which setting I have to change to have MPG transcoded as well?
TIA,
Arthur Dent
* - disable transcoding at all
