i test dlna server on my home network ( whs french).
i would like to  'serve' my samsung ue40b700, my wii, and 3 pc in my home network and i try:
twonki ( kick off) no run correctly with video!
serviio ( kick off) two young ( for now!)
tversity : only server would work with my WII , my TV and PC but no thumbail with the tv.
WMS: works with PC, WII ( I trie!) and tv ( without thumbail for audio streaming).
how i can fixe it ?
							[ok]:How to have thumbail with audio files with my samsung?
						Re: How to have thumbail with audio files with my samsung?
TV can not show thumnails to any server. They appear with the Samsung PC Share Manager?lecureuil wrote:i test dlna server on my home network ( whs french).
how i can fixe it ?
audio thumbail are available with servio and twonki, i have not test samsumg pc share.
Thumnails exists in "Music information" ? (on right click "mouse" in the list of music - Edit information). Which navigation elements are displayed thumbnails with servio and twonki ?lecureuil wrote:audio thumbail are available with servio and twonki, i have not test samsumg pc share.
for twonki an serviio , i dont know because both software are uninstall now!
for each album i have cover.jpg and folder.jpg file and all my mp3 are tagged with a thumbail inside.
i try to modify and set thumbail with edit information, but nothing.
I discover if you share a like "\\server \vidéos" you dont have thumbail but if the share is like "\\server\videos" you have thumbails. but i dont kown why it dosn't work only for audio. I share music from "\\lecureuil\musique" there is no coma on this!
I checked the transfer of information about the thumbnails on the same files in the WMS and PC Share Manager, no significant differences.lecureuil wrote:for twonki an serviio , i dont know because both software are uninstall now!
SEREVIIO use upnp:albumArtURI to display the thumbail
WMS and PC Share Manager toolecureuil wrote:SEREVIIO use upnp:albumArtURI to display the thumbail
i install PC Share Manager and audio (and other) thumbail are displayed on my UE40B7000.
how i can enable it with WMS?
In Settings-Additional you can enable a debug log, the same, you can view and save. After enabling the debug log, go to the TV in the folder where the thumbnails should be. Debug log can be studied independently or attach to the forum in the archive or send it to support@wildmediaserver.com.lecureuil wrote:i install PC Share Manager and audio (and other) thumbail are displayed on my UE40B7000.
