Hi
I've just installed CoreAVC 2.5.5.0 and under "File Types" in WMS I've choosen "Movies - CoreAVC" as transcoding profile for MKV, MP4 and MTS.
When playing MKV files the video begins to be out of sync. Sound is ahead with maybe 2 seconds. In the beginning it's fine but the issue occurs after 10-20 minutes.
Also, when trying to play MP4 files is says "Error (code: 80004005) - unspecified error" under the "Message Log".
I have CoreAVC, AC3Filter, FFDShow and Haali Media Splitter installed. My TV is a Sony Bravia KDL32EX710 and I've choosen "Sony TV (DLNA, 16:9, 1920x1080)" as device type.
Any settings I should change?
						Problems with MKV/MP4 and CoreAVC...
Re: Problems with MKV/MP4 and CoreAVC...
Find
Replace with
Ok - Ok - Ok
						Via the folder Transcoding you can to choose playback from any minute.Greenduck wrote:
Settings - Transcoder - Profiles - "Movies - CoreAVC" - EditGreenduck wrote: Also, when trying to play MP4 files is says "Error (code: 80004005) - unspecified error" under the "Message Log".
Find
bMpegTS := SameText(mpFileType, 'mpegts');Code: Select all
bMpegTS := SameText(mpFileType, 'mpegts') or (Pos('mp4', mpFileType) > 0);
