Autodetect the device type
In version 1.10.1 - http://www.wildmediaserver.com/forum/vi ... &f=3#p6678, added setting for auto-detect the device type.
The device type is determined by the score, which is gaining device configuration, depending on the parameters of the request or response from device.
Maximum score 100, minimum 0.
Script to determine the score.
Scripts are three types.
1. Language: No Script; without specifying the score (score 100, if the string is present in RequestClientName)
Example:
PLAYSTATION
2. Language: No Script; with specifying the score
Example:
75;INTEL_NMPR/2.1 DLNADOC/1.50 dma/3.0 alphanetworks
100;WDTV
3. Language: PascalScript | BasicScript | JScript | C++Script
  if (Pos('LG DLNA DMC', RequestClientName) > 0) or (Pos('LG-HTTPCLIENT', RequestClientName) > 0) then
    DeviceTypeScore := 100
  else if (ResponseBody <> '') and (Pos('LG Digital Media Renderer TV', ResponseBody) > 0) then
  else
    DeviceTypeScore := 0
Variables available in the script
DeviceTypeScore - the score
Request from the device to the server
RequestClientName - field User-Agent from request header or name of device, extracted from request header by the program (value in upper case)
RequestHeader - request header
RequestUserAgent - field User-Agent from request header
Response from the device to the server - UPnP description of device
ResponseBody - description of the device
ResponseHeader - response header
ResponseUserAgent - field User-Agent from response header
Editing scripts
1. Settings - Devices - choose a device - Settings - Type - click "Auto-detect the device type"
2. Script editing - Ok
3. click "Save settings for this type"
4. Save current settings as default settings for this device type ? - Yes
Re: Autodetect the device type
Editing scripts without the list of authorized clients
1. Settings - Devices - "Device type by default" - click "Settings"
2. Type - choose a type of device - click "Auto-detect the device type"
3. Script editing - Ok
4. click "Save settings for this type"
5. Save current settings as default settings for this device type ? - Yes
6. Cancel - Cancel
7. Save changes ? No
