Justin.tv
Justin.tv
justintv.zip
(1.83 KiB) Downloaded 1375 times
2. Drag and drop justintv.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Justin.tv". If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file justintv.wdf by right click in the folder tree.
3. Download new version rtmpdump.exe - http://www.wildmediaserver.com/files/rtmpdump.zip
4. Extract rtmpdump.exe to ?:\Program Files\Wild Media Server\Transcoders
5. Select the folder "Justin.tv" - List [Movies] - right click - "Add Link" - Title: Channel title; Path: channel link - Ok
2011/07/29 Updated (new version rtmpdump.exe & justintv.wdf)
2011/08/18 Updated (site link http://www.jtvx.com)
yHo
Re: Justin.tv
Post by yHo »
Like it but it's not working for me. It says that the file is not supported.
Justin.tv just change is name to twitch.tv. could it be the cause?
Re: Justin.tv
yHo wrote:Like it but it's not working for me. It says that the file is not supported.
The problem exists, perhaps the solution will come later. Thanks for notice.
Re: Justin.tv
Fixed (at least for me)
Re: Justin.tv
Updated
WeBe
Re: Justin.tv
Post by WeBe »
Doesn't work for me on my Samsung TV. When playing, the transcoding on the server is not starting and the TV says that the format is not supported. Anyone knows the problem/solution?
Re: Justin.tv
WeBe wrote:Doesn't work for me on my Samsung TV. When playing, the transcoding on the server is not starting and the TV says that the format is not supported. Anyone knows the problem/solution?
Probably not have access to the Internet in a service mode. I have no problems on Samsung TV
