Hello!
I use Server 2008 R2 for the Software with standard Windows Firewall.
After the update to 1.09.1 i have problems with the daemon, bevore i haven´t.
In daemon mode every thing works fine exept video watch transcoded AND original.
There is a black screen for a half second and then it stop.
When i start the software as Aplication everything works normal!
A Reinstall with the old DB haven´t solve the Problem.
Firewall entries are the same!
I canged for test the daemon user from System to Administrator with no luck.
Firewall Config:
Inbound:
TCP 45357
UDP 1900
wmssvc.exe
wms.exe
Outbound:
UDP 1900
wmssvc.exe
wms.exe
This should be not the Problem.
DB Reset is not my lucky way because i invested a lot of work.
I hope you can help me!
Peter
Problem with the daemon
Re: Problem with the daemon
Yes, it worked for me.
