vob files are separated in folders and won't play next folde
meram
Post by meram »
Now I am getting really frustrated :? . Yesterday I spend hole day till 2 o'clock in the night and today whole day.....
I want to play vob files with Dutch subs. Till now I only get it working if I use the DVD structure maps button in WMS. Than I can select it in de folder to Dutch subtitles.
What's my issue?
After the vob01 file in the folder is finished playing it should skip to the next folder so it will play vob02 etc. But it won't start the next folder automatic.
So I have manually go to the next folder. If I don't use de DVD structure button I can not select the subtitles
Has someone a solution for me,
thanks in advanced, Meram :roll:
(is there also an easy way to skip to an other chapter (TV series like friends, in WMP I can select the chapter in WMS I can't)
Re: vob files are separated in folders and won't play next f
Navigation on device: Transcoding - "Media resources folders" - ...
meram
Post by meram »
i added two printscreens Eugene. Because i dont get it :(
