TheStreamDB.com - an open database for live streaming media
TheStreamDB.zip
(3.82 KiB) Downloaded 3528 times
1. Unzip.
2. Settings - Processing - Load - thestreamdb_processing.cfg - "Clear the current Processing scripts of media resources list ?" No - Ok -Ok
3. Settings - Transcoder - Profiles - Load - thestreamdb_transcode.cfg - "Clear current lists ?" - No - Ok - Ok - Ok
4. The folder "Internet - Television" - right click - "Add folder" - Title: TheStreamDB.com - Path: http://www.thestreamdb.com - Ok
5. The folder "TheStreamDB.com" - right click - "Add folder" - Title: English - Path: http://www.thestreamdb.com/db/English - Ok
6. The folder "English" - click the button "TheStreamDB.com"
Repeat 5-6 for other required sections of http://www.thestreamdb.com (link on right click "Copy shortcut" in Internet browser)
P.S. Required version 1.09rc2 or above
Updated 2011/06/06
Updated 2011/06/18
Rheingold
Re: TheStreamDB.com - an open database for live streaming me
Post by Rheingold »
in the two scripts the PCRE_SINGLELINE and PCRE_MULTILINE constants are missing!
I think the values are $5 and $2.
Greetings
Rheingold
I edited the description (version 1.09rc2 or above)
You are right about the values
ira wrote: The Stream - I updated WMS to 1.10rc2, followed your instructions thru Step 6. I see all the streams when in English. I do not hear or see anything after clicking on many streams.
Link to the stream formed in the transcoding profile. You can not open stream by click. You can use the test transcoding, check availability (right click), playback on device, web-navigation.
ira wrote: What does "Repeat 5-6 for other required sections of http://www.thestreamdb.com (link on right click "Copy shortcut" in Internet browser" mean? Do I need to correct your script?
Open http://www.thestreamdb.com/ in Internet Browser. List of languages ​​and countries on the right (sections).
Link to language, country on right click "Copy shortcut" (for example Français - http://www.thestreamdb.com/db/French)
Follow 5-6 steps
samsungfan
Post by samsungfan »
How can you debug the scripts for the transcoding profile?
ira wrote:Evgeny,
Tried from Transcoded stream. Tried testing Transcoding on one stream. Did not receive any indication that. Went to TV. Drilled into transcoded folder to each stream. All subfolders include "?" Essentially none of the streams include any audio or video data. See attachment.
Ira
Changes on the site, the transcoding profile updated. You need to delete the profile transcoding "TheStreamDB.com". Load new version.
samsungfan wrote:How can you debug the scripts for the transcoding profile?
List [Movies] - select a link - Settings - Transcoder - Profiles - TheStreamDB.com - Edit - click "Run script by steps"
samsungfan
Thanks. If i need to debug against a particular item. i guess i need to set the mpFilePath before debugging???
samsungfan wrote:Thanks. If i need to debug against a particular item. i guess i need to set the mpFilePath before debugging???
Just select a link in List [Movies].
mrc960 wrote:I followed the instructions step 1 to 6 to add the english streams. When clicking the button "TheStreamDB.com" I did not get the Entertainment category which is listed on the http://www.thestreamdb.com/db/English page.
I noticed that this category is missing for all other langauges I downloaded from theStreamDC.com.
I've installed WMS Verson 1.10rc4.
Any help?
Thanl you!
Changes on the site, updated
