Internet Stream
rtmpmaster
Internet Stream
Post by rtmpmaster »
Dear Eugene,
How do I specify rtmp parameters such as app and playpath in rtmp stream. I am able to type it in cmd using rtmpdump and get an output but I am not sure of how to type it in when adding a stream. Good job on your WWI plugin. The rtmp streams that are on WWI work fine.
Thank You In Advance
Re: Internet Stream
New version "Movies - RtmpDump - FFMPEG"
movies_rtmpdump_ffmpeg.zip
(1.6 KiB) Downloaded 1069 times
2. Settings - Transcoder - Profiles - "Movies - RtmpDump - FFMPEG" - Delete - Yes - Load - movies_rtmpdump_ffmpeg.cfg - "Clear currents lists ?" - No - Ok - Ok - Ok
3. The folder "Internet - television" - List [Movies] - right click "Add Link" - Path -
rtmpdump -r "..." -y "..." -W "..." -p "..." ... (without -o)
Ok
right click - Transcoding profile "Movies - RtmpDump - FFMPEG"
rtmpmaster
Re: Internet Stream
Thank You Eugene, you've been very helpful.
