Hello everyone.  First off, I want to say that this is a great program.  I've tried about 6 different servers and this one so far is the best.  I have 3 days left on my trial and I can not figure out how to get to stream the internal subtitle track of mkv files.  I have a Samsung 40D6420 TV.
I've read just about every thread on here dealing with mkv files and subtitles.  I can see the subtitle track in the file information.  I've selected "Always transcode if subtitles are present".  I don't know what to do.  I reinstalled it last night to get a fresh start, as I've read that some people were able to get subtitles to work after restarting, but no luck for me.
If someone could give me a step by step on how to get internal subtitles to stream with mkv files i'd really appreciate it and will gladly purchase this software as soon as I can get it to work.  Below is the file information.  Most of what I watch is anime and they are all 720p mkv files.
Thanks in advance for any help.
Property name/value |  |
 - | General |
  |  | Complete name: H:\Torrents\[HorribleSubs] Bleach - 302 [720p].mkv
  |  | Format: Matroska
  |  | File size: 280 MiB
  |  | Duration: 24mn 4s
  |  | Overall bit rate: 1 624 Kbps
  |  | Encoded date: UTC 2010-12-21 09:34:20
  |  | Writing application: mkvmerge v4.0.0 ('The Stars were mine') built on Jun  6 2010 16:18:42
  |  | Writing library: libebml v1.0.0 + libmatroska v1.0.0
  |  | Cover: Yes
 - | Video |
  |  | Format: AVC
  |  | Format/Info: Advanced Video Codec
  |  | Format profile: High@L4.0
  |  | Format settings, CABAC: Yes
  |  | Format settings, ReFrames: 8 frames
  |  | Muxing mode: Container profile=Unknown@4.0
  |  | Codec ID: V_MPEG4/ISO/AVC
  |  | Duration: 24mn 4s
  |  | Nominal bit rate: 1 500 Kbps
  |  | Width: 1 280 pixels
  |  | Height: 720 pixels
  |  | Display aspect ratio: 16:9
  |  | Frame rate: 23.810 fps
  |  | Original frame rate: 23.976 fps
  |  | Color space: YUV
  |  | Chroma subsampling: 4:2:0
  |  | Bit depth: 8 bits
  |  | Scan type: Progressive
  |  | Bits/(Pixel*Frame): 0.068
  |  | Writing library: x264 core 98 r1629 2e81ce1
  |  | Encoding settings: cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=3486 / vbv_bufsize=3487 / ip_ratio=1.40 / aq=1:0.50 / nal_hrd=none
 - | Audio |
  |  | Format: AAC
  |  | Format/Info: Advanced Audio Codec
  |  | Format version: Version 4
  |  | Format profile: LC
  |  | Format settings, SBR: No
  |  | Codec ID: A_AAC
  |  | Duration: 24mn 4s
  |  | Channel(s): 2 channels
  |  | Channel positions: Front: L R
  |  | Sampling rate: 44.1 KHz
 - | Text |
  |  | Format: ASS
  |  | Codec ID: S_TEXT/ASS
  |  | Codec ID/Info: Advanced Sub Station Alpha
