I use YAMMM to automatically update my movie collection with data from IMDB. This creates a mymovies.xml file containing information about the actors/directors, ratings, genres etc. It also creates a folder.jpg and some other cover.jpgs too.
I've written a little script that will look in the folder of the movie for this mymovies.xml file and automatically populate this information within WildMediaServer. It'll also set the thumbnail image to the Folder.jpg.
Please feel free to use/modify the code in anyway.
I've not written any PascalScript before so go easy on me but I'd welcome any comments too.
NOTE: This will overwrite all the information you may have entered manually.
function GetThumbnail( XMLRoot : TXMLItem ) : string;
   var XMLCovers : TXMLItem  ;
   XMLCovers := XMLRoot.Find("Covers");
   Result := "";
   if XMLCovers <> nil then
      Result := XMLCovers.Find("Front").Value;
procedure GetPeople( XMLRoot : TXMLItem;
                     var actors : string;
                     var directors : string;
                     var producers : string;  );
   var XMLPeopleRoot : TXMLItem;
   var XMLPerson : TXMLItem;
   var Name: string;
   var i : Integer;
   actors := "";
   directors := "";
   producers := "";
   XMLPeopleRoot := XMLRoot.Find("Persons");
   if XMLPeopleRoot <> nil then begin
      for i := 0 To XMLPeopleRoot.Count - 1 do begin
         XMLPerson := XMLPeopleRoot[i];
         Name := XMLPerson.Find("Name").Value;
         if XMLPerson.Find("Type").Value = "Actor" then begin
            if Length(actors) = 0 then
               actors := Name
            else
               actors := actors + "," + Name
         else if XMLPerson.Find("Type").Value = "Director" then begin
            if Length(directors) = 0 then
               directors := Name
            else
               directors := directors + "," + Name
         else if XMLPerson.Find("Type").Value = "Producer" then begin
            if Length(producers) = 0 then
               producers := Name
            else
               producers := producers + "," + Name
function GetGenres( XMLRoot : TXMLItem ) : string;
   var XMLGenreRoot : TXMLItem;
   var genres : string;
   var i : Integer;
   XMLGenreRoot := XMLRoot.Find("Genres");
   genres := "";
   if XMLGenreRoot <> nil then begin
      for i := 0 To XMLGenreRoot.Count - 1 do begin
         if Length(genres) = 0 then
            genres := XMLGenreRoot[i].Value
         else
            genres := genres + "," + XMLGenreRoot[i].Value
   Result := genres;
function GetItemAsString(XMLRoot : TXMLItem; requiredData : string) : string ;
   var XMLItemData : TXMLItem;
   XMLItemData := XMLRoot.Find(requiredData);
   if XMLItemData <> nil then
      Result := XMLItemData.Value
   else
      Result := ""
procedure ImportMetaData(XMLRoot : TXMLItem; TheMediaItem : TWmsScriptMediaItem);
   var title, description, year, runningTime, rating: string;
   var actors, directors, producers : string;
   var XMLTitle: TXMLItem;
      title :=  GetItemAsString(XMLRoot, "LocalTitle");
      description := GetItemAsString(XMLRoot, "Description");
      rating := GetItemAsString(XMLRoot, "IMDBrating");
      year := GetItemAsString(XMLRoot, "ProductionYear");
      runningTime := GetItemAsString(XMLRoot, "RunningTime");
      TheMediaItem.Properties[mpiTitle] := title;
      TheMediaItem.Properties[mpiYear] := year;
      TheMediaItem.Properties[mpiComment] := description;
      TheMediaItem.Properties[mpiRating] := rating;
      TheMediaItem.Properties[mpiGenre] := GetGenres(XMLRoot);
      TheMediaItem.Properties[mpiThumbnail] := GetThumbnail(XMLRoot);
      GetPeople(XMLRoot, actors, directors, producers);
      TheMediaItem.Properties[mpiActor] := actors;
      TheMediaItem.Properties[mpiDirector] := directors;
      TheMediaItem.Properties[mpiProducer] := producers;
function GetMetaDataForItem(TheMediaItem : TWmsScriptMediaItem) : boolean;
var loadDir, movieXmlFileName, fullPath: string;
var XMLDocument: TXMLDocument;
   Result := false;
   movieXmlFileName := "mymovies.xml";
   loadDir := IncludeTrailingBackslash(ExtractFilePath(TheMediaItem.Properties[mpiFilePath]));
   fullPath := loadDir + movieXmlFileName;
   if FileExists(fullPath) then begin
      XMLDocument := TXMLDocument.Create;
      try
         XMLDocument.LoadFromFile(fullPath);
         if XMLDocument.Root.Name = "Title" then begin
            ImportMetaData(XMLDocument.Root, TheMediaItem);
            Result := true;
      finally
         XMLDocument.Free
  i, iSuccessCount: Integer;
  MediaItemList: TWmsScriptMediaItemList;
  MediaItemList := WmsCurrentMediaListItems;
  try
    iSuccessCount := 0;
    if MediaItemList.Count > 0 then begin
      WmsShowProgress('Load metadata...');
      try
        for i := 0 to MediaItemList.Count - 1 do begin
          if WmsCancelPressed then
            Break
          else begin
            if GetMetaDataForItem(MediaItemList[i]) then
               Inc(iSuccessCount);
            WmsSetProgress(Round(((i + 1) / MediaItemList.Count) * 100))
      finally
        WmsHideProgress
      MessageDlg('Load aborted by the user.', mtError, mbOK, 0)
    else if iSuccessCount > 0 then
      MessageDlg('Load metadata was successful.', mtInformation, mbOK, 0)
    else
      MessageDlg('No information available for load.', mtError, mbOK, 0)
  finally
    MediaItemList.Free
  WmsDatabaseAutoSave;
  ProcessMediaResult := True
