I just upgraded from 1.8.2 to the latest 1.9.
Everything looks normal from my Sony Bravia TV until ... there is no video. Everything is normal until it is time for the video to show. Connection, menues, thumbnails are all OK.
Any suggestions? No changes other than the upgrade.
mr.purcell
No Video
Re: No Video
Maybe the same problem - http://www.wildmediaserver.com/forum/vi ... =20&t=1043mr.purcell wrote:I just upgraded from 1.8.2 to the latest 1.9.
Re: No Video
Using a Windows 7 PC I had the same issue with my Sony BDP-S370 BluRay player after upgrade 1.08.2 to 1.09.
I have WMS configured to start up automatically (but not as a service). After the PC started up I checked the BluRay player all the menus were there but the videos wouldn't play. If I exited the WMS program on the PC and started it manually it then worked OK, so there seems to be something wrong with the WMS startup timing (or dependencies) on the PC.
I fixed this issue on my PC by installing a free "Startup Delayer" program and delaying WMS for 60 seconds after PC boot-up. Now everything works fine.
