Released version "Wild Media Server (UPnP) v1.09.1"
Update file from version 1.08.2
How to update the program:
1. Download the update file.
Wild Media Server (UPnP, DLNA, HTTP) v.1.09
1. Added device configuration:
- "Dune Media Player (UPnP, 16:9, 720x406)";
- "Popcorn Hour Media Player (DLNA, 16:9, 720x406)";
- "Samsung Features TV (DLNA, 16:9, 720x406)".
2. In the settings of podcasts added "Priority of video formats" (setting should be
used in the scripts links to video).
3. In the settings of podcasts added schedule for update (button Schedule).
4. In the settings of podcasts added the possibility of customization for client devices
(button "Devices").
5. Module libraw-lite.dll replaced on libraw.dll (support for digital cameras RAW-files);
6. In the settings of client device added "Working time";
7. Added mode "Indicator of availability of the Internet resources" (Settings - "Media-
resources" - "Internet-resources" - "Check the availability of Internet resources").
8. Added settings for loading custom playlists (Settings - Playlists);
9. Individual transcoding settings of movie (List [Movies] - select a file - right click -
"Special settings...");
10. Updated Bulgarian, French, German, Italian, Polish translation files;
11. Updated transcoder FFMPEG - added wtv-files support.
12. Updated subtitles module.
13. Added transcoding profiles "Movies - RTMPDUMP - FFMPEG",
"Music - RTMPDUMP - FFMPEG".
14. Added mode "Disable the transmission of information about external subtitles"
(Settings - Transcoder - Subtitles or Settings - Server - choose a device - Edit -
Settings - Subtitles).
Update to version 1.09.1
- transcoder FFMPEG replaced from version 1.08.2 (problems with "out of memory" on m2ts-streams, problems with changing channel quantity, problems with wtv-files, ...);
- update Bulgarian, German translation files.
Banker_2
Re: Released a version "Wild Media Server (UPnP) v1.09"
Post by Banker_2 »
I have version 1.08.4 - how to update the WMS to version 1.09? :?
meram
Post by meram »
I also have 1.08.4
I can i update to 1.09 without the risk i loose all my settings?
Gerards
Meram
meram wrote:I also have 1.08.4
Help - Backup
skyone
Post by skyone »
meram wrote: I also have 1.08.4
Gerards
Meram
:idea: :idea: :idea:
i think you can go trough all the process: :o
download the 5 files :
.... and install one by one .... from 1.08.4 to 1.09RC1 -> RC2 -> RC3 ->RC4 -> 1.09 :mrgreen:
this for 1.09.1:
REGARDS
WMS bought on 2010.10.25 - TV Sony 46EX700 - WMS 32 bit
rickymartin
Post by rickymartin »
Hi I did some changes in files regarding this forum (no solution for me, now movies are not playing like before) and now I would like to set all to default. How to reinstall it with the easiest way?
rickymartin wrote:I did some changes in files regarding this forum (no solution for me, now movies are not playing like before) and now I would like to set all to default. How to reinstall it with the easiest way?
Settings - Server - choose a device - Edit - Settings - Type - choose a type of device
rickymartin
Eugene, thank you for your advise. Finally I had to uninstall WMS (data files not erased) completly and install it again brand new version 1.09. It works now fine again. I found one new thing on my Sony tv, that if picture is sctreched I can increase it by tv remote controler to full screen! Especially on my Sony there are Wide screen, Smart and Zoom. Zoom works great for me.
Eugene wrote:Hi,
Re: Released a version "Wild Media Server (UPnP) v1.09.1"
banafaen
Post by banafaen »
none of the podcasts work (in windows service) after new version.
Works if i uninstall service an run wms.
any tips? I've checked firewalls etc
-bana
