Need help with two of the best podcasts
wildone1965
Post by wildone1965 »
Hello Eugine,
can you please help me with the 2 best podcast shows?
http://www.thedailyshow.com/
and
http://www.colbertnation.com/home
they dont work with the original settings posted here. (Comedy Central or just the 2 shows posted here)
could you please create a new one.
Thank you so much
Re: Need help with two of the best podcasts
wildone1965
Hello Eugene,
unfortunately the podcasts wont work for me.
I cant update the podcasts and i cant view them, even though they show up in webbrowser.
in the screenshots you can see an error message i am getting, but i dont know if this has something to do with me not being able to see the podcasts. If you need additional information let me know.
ScreenHunter_02 Apr. 05 08.22.jpg (57.17 KiB) Viewed 10973 times
ScreenHunter_03 Apr. 05 08.23.jpg (93.15 KiB) Viewed 10973 times
ScreenHunter_04 Apr. 05 08.23.jpg (42.81 KiB) Viewed 10973 times
wildone1965
ScreenHunter_05 Apr. 05 08.23.jpg (33.49 KiB) Viewed 10973 times
Folder [Movies] - right click - "Restore folders" - must appear the folder "Podcasts"
Remove all Comedy Central folders
Add again comedycental.wdf
wildone1965
Thank you for your fast reply. I did everything according to your answer and i can see the podcasts now in the main window. I cant run a test transcoding, even though the podcasts play on webbrowser. I cant view them on my TV either. The message i get is "Access to Server not possible. Check your serversettings". What am i doing wrong this time?
