problem with fps dropping and other stuff
slasherkill
Post by slasherkill »
hello,
nice program you have there! But I do have som small problems.
I have attached my computer info so that you can see the specs. And I have also attached the video info for one of the files that I have problems with.
When I watch Avatar in 1920X1080 the movie starts out fine, but after around 24 minutes it starts to lag. But the funny thing is that the FPS is still 28. So how come it lags?! The CPU is not overloaded either.
It looks like it works with most movie files, but the ones that are mkv. I have a sony BDP-s370 bluray player. Using wireless connection.
fps avatar
fps avatar
fps lag avatar.jpg (218.96 KiB) Viewed 17112 times
video info avatar
video info avatar
video info avatar.jpg (100.39 KiB) Viewed 17112 times
pc info
pc info
pc info.jpg (43.86 KiB) Viewed 17112 times
slasherkill
Re: problem with fps dropping and other stuff
and most times the movies work for some time, before they start to lag. why is that?
also this movie. but now I use transcoder core avc. But the picture moves slow... fps is 150.
video info rush hour 2.jpg (91.45 KiB) Viewed 17110 times
Transcoding buffer is enabled ? (Settings - Transcoder - Other)
slasherkill
yes it is.
any other clues?
slasherkill wrote:yes it is.
any other clues?
I think the problem with wireless connection
slasherkill
how can you say that?
this problem does not occour right away, but after some time. Sometimes not before 24 minutes.
slasherkill
hello`?
Several factors: maybe slow disk, wireless connection, mTorrent
Need to try different variants
slasherkill
mtorrent??
I will try a different disk now. but it seems like it happens at the exact same spot everytime. I have now even pretranscoded the movies rush hour 2 and avatar. still have problems.
slasherkill
I tried another disk, still the same problem. The movie start to stutter at the EXACT same spot again. Even when pretranscoded.
