Hello
I am posting here but I am not sure about the problem, I am not sure that the problem have to do with the tv
I am having problems with wms. When I don't use wms for a long time, one or two week, my tv can't connect to the server. I don't know why because everything is the same that two week ago was working fine.
It did happen two times and the solution was uninstall and install wms again, apply license, scan, etc. And that is relly annoying.
Any help?
Thanks in advance
sony 32ex500
Re: sony 32ex500
(in any case, no need uninstall - just check settings)
You can remove the IP-address - http://www.wildmediaserver.com/forum/vi ... &f=3#p4898paltibet wrote: I am posting here but I am not sure about the problem, I am not sure that the problem have to do with the tv
Any help?
Re: sony 32ex500
It worksEugene wrote:Hello,You can remove the IP-address - http://www.wildmediaserver.com/forum/vi ... &f=3#p4898paltibet wrote: I am posting here but I am not sure about the problem, I am not sure that the problem have to do with the tv
Any help?
