Digital Video Broadcasting (DVB)
laedu
Post by laedu »
I have a DVB-S device and i would like to make a transport stream available with upnp.
How can i get this?
Re: Digital Video Broadcasting (DVB)
laedu wrote:I have a DVB-S device and i would like to make a transport stream available with upnp.
How can i get this?
For transcoding Digital Video Broadcasting (DVB) is used DVPIPER (http://www.cs.usyd.edu.au/~efax/DVPiper.html)
There are problems with reading the properties of channels :( , will be fixed in the next version, possibly tomorrow
adamgillett
Post by adamgillett »
I'd like to set up my DVB-T card (Intel CE9500 DVB-T). When I follow your guide and press scan nothing comes up. Do I need to set the other available parameters in the box first. I live in the UK, and am not sure what I would need to enter? Has anybody else been successful?
ZvonacIG
Post by ZvonacIG »
I have a problem with this part of the program :
I understand that I miss MEncoder and ffmpeg, I have installed both and all those other programs in the folder: local settings / temp / xxx as winrar automatically made extraction , my DVB-T channels are founded and streamed to my TV , but ffmpeg is being crashed on Windows ,and error says something about AMD
I have Intel Core2 Duo ,and Win XP SP2 ,please what programs I need to download and where to extract them
http://sourceforge.net/projects/mplayer-win32/files/
I do not know which programs should I choose :?:
Do I need something to change in the settings, because we use 4:3 DVB-T aspect ratio
ZvonacIG wrote:I have a problem with this part of the program :
If the device does not support MPEGTS stream, then use transcoding profile "Digital television (DVB) - DVPiper".
