cg346
Post by cg346 »
so, i installed again. changed nothing expect "settings-file types"
.avi files play perfectly no matter what formats.
.divx and .mov needs to buffer very quickly.
.mkv: i get audio and just the "pixelled puzzle" or no picture at all...
what is best to set as buffer size? the higher the better?
there must be a problem somewhere...?!
chris
cg346
Post by cg346 »
when i copy the transcoded .mkv file to an USB and play it via this on the TV is plays perfectly...
can anybody help?? :(
chris
cg346 wrote:when i copy the transcoded .mkv file to an USB and play it via this on the TV is plays perfectly...
chris
If you use a profile transcoding Movies (primary) and the speed of transcoding is not enough for viewing in real time, then you can stop the playing for the formation of transcoded content or use pre-transcoding (http://www.wildmediaserver.com/forum/vi ... p=187#p187).
cg346
Post by cg346 »
in settings-file types-mkv, i removed the transcoding profile TsMuxer and now it plays the files! it now creates a .mpg files... :)
pre-transcoding means it transcodes the entire movie before playing?
cg346 wrote:in settings-file types-mkv, i removed the transcoding profile TsMuxer and now it plays the files! it now creates a .mpg files... :)
Yes
