so, i installed again. changed nothing expect "settings-file types"
.avi files play perfectly no matter what formats.
.divx and .mov needs to buffer very quickly.
.mkv: i get audio and just the "pixelled puzzle" or no picture at all...
what is best to set as buffer size? the higher the better?
there must be a problem somewhere...?!
chris
- 11.JPG (95.36 KiB) Viewed 10660 times
when i copy the transcoded .mkv file to an USB and play it via this on the TV is plays perfectly...
can anybody help??
chris
can anybody help??
chris
If you use a profile transcoding Movies (primary) and the speed of transcoding is not enough for viewing in real time, then you can stop the playing for the formation of transcoded content or use pre-transcoding (http://www.wildmediaserver.com/forum/vi ... p=187#p187).cg346 wrote:when i copy the transcoded .mkv file to an USB and play it via this on the TV is plays perfectly...
can anybody help??
chris
in settings-file types-mkv, i removed the transcoding profile TsMuxer and now it plays the files! it now creates a .mpg files...
pre-transcoding means it transcodes the entire movie before playing?
Yescg346 wrote:in settings-file types-mkv, i removed the transcoding profile TsMuxer and now it plays the files! it now creates a .mpg files...
