List songs by album track number?
Re: List songs NOT by album track number?
MartinSch wrote:Sorry, been studying but don't get it.
I would also like to list the tracks by Song title ("Track name"). But in front of the name is the track number. How do I get rid of the track numbers in front of the song. Is it possible to simply use the tag of the trackname?
Settings - Devices - choose a device - Settings - turn on "Include track number in the music media resource title"
MartinSch
Post by MartinSch »
No, this does not help. Still Tracknumber before the Song title, and I want JUST the song title. See attached picture.
This is what I see in the media folders.
Track number + name.jpg (44.53 KiB) Viewed 98700 times
WMS 1.50.3 / TV Panasonic Viera TX-L37DT35E
Sorry,
Settings - Devices - "Device type by default" - Settings (small button) - turn off "Include track number in the music media resource title" - Ok - Ok - click Renew
P.S. You can use "Expression grouping":
Copy(mpTitle, 1, 1) + '\' + mpTitle
MartinSch
Post by MartinSch »
Eugene wrote:Sorry,
I could not find "Device type by default". My Devices-screen has one small button only, which says "Settings", to the right of "Select from list". It seems to do the same as the big "Settings" in right margin... but it's in fact different!!! It works, great!
Also your PS works perfect, saves a level...
Eugene, seriously, if you will develop a thorough Help system then WMS will be worth 10x as much. Or maybe set up a Wiki, so all users can contribute. I will contribute my notes for sure.
For now, thanks.
MartinSch wrote: I could not find "Device type by default".
MartinSch wrote: Eugene, seriously, if you will develop a thorough Help system then WMS will be worth 10x as much. Or maybe set up a Wiki, so all users can contribute. I will contribute my notes for sure.
Illusions already aren't present
MartinSch
Post by MartinSch »
Eugene wrote:P.S. You can use "Expression grouping":
Could I omit the A's and The's, by coding something like this? :
if Copy(mpTitle, 1, 2) = "A "
   then Copy(mpTitle, 3,1) + '\' + Copy(mpTitle, 3, 50)
else if Copy(mpTitle, 1, 4) = "The "
   then Copy(mpTitle, 5,1) + '\' + Copy(mpTitle, 5, 50)
else  Copy(mpTitle, 1, 1) + '\' + mpTitle
MartinSch
AAC's have no Artist
Post by MartinSch »
All my MP3 files have correct Artists. But all the AAC-files have Artist = Unknown, and indeed do not show an Artist in the columns.
Is there a setting to correct this?
You need set the variable FolderPath, FolderPath := ...
   then FolderPath := Copy(mpTitle, 3,1) + '\' + Copy(mpTitle, 3, 50)
   then FolderPath := Copy(mpTitle, 5,1) + '\' + Copy(mpTitle, 5, 50)
else  FolderPath := Copy(mpTitle, 1, 1) + '\' + mpTitle
Re: AAC's have no Artist
MartinSch wrote:All my MP3 files have correct Artists. But all the AAC-files have Artist = Unknown, and indeed do not show an Artist in the columns.
You can update to version 1.51 - http://www.wildmediaserver.com/forum/vi ... f=3&t=1539
Select a file(s) - right click - "Load file properties"
MartinSch
Post by MartinSch »
Yes, this solved the problem, thanks.
