Eugene. Here is something I think we can work with, RSS feed from TED and PBS as examples. If we can make this work, I can volunteer to add all the RSS feeds from these websites and share it with everybody.
http://feeds.feedburner.com/TedtalksHD
http://www.pbs.org/newshour/rss/science.xml
I am able to add both these RSS to the respective folders of PBS and TED under podcasts. On my Samsung LN46C630 HDTV, I am able to even browse the folder and look at the video names, but when I play I get an error message "File Format Not Supported".
Will appreciate your help in resolving this issue.
Pbs.org, c-span.org and ted.org
Re: Pbs.org, c-span.org and ted.org - RSS Feeds
Select the folder "Podcasts" - right click - Add Podcast - Link: http://feeds.feedburner.com/TedtalksHDtech.whiz wrote:Eugene. Here is something I think we can work with, RSS feed from TED and PBS as examples. If we can make this work, I can volunteer to add all the RSS feeds from these websites and share it with everybody.
"The additional properties reading script RSS" - On - "Edit script"
Language: PascalScript
Expression:
PodcastItem.Properties[mpiThumbnail] := PodcastXmlItem.Find('media:thumbnail').Attributes['url']
Maybe: Transcoding profile: Movies (primary)
Select the folder PBS - right click - "Edit title" - "Script for the links to the resource" - "Edit script" -tech.whiz wrote: http://www.pbs.org/newshour/rss/science.xml
Find
else if WmsRegExMatch('DetectFlashDecision \('#39'.*?'#39', '#39'(.*?)'#39, sVideoPage, sVideoID) then begin
else if WmsRegExMatch('DetectFlashDecision.*?\('#39'.*?'#39', '#39'(.*?)'#39, sVideoPage, sVideoID) then begin
Thanks Eugene. TED is now working for me, thank you for your quick help.
For PBS, I am still getting the same error.
I was looking at the script you sent and noticed something which might be causing some problem and thought should check with you.
function YoutubeLink(const aVideoID: string): string;
bRtmp, bUsePriority: Boolean;
i, j, iPriority, iMinPriority, iHeight: Integer;
sMediaFormats, sVideoFmtURLMap, sVideoFormat, sVideoInfo,
sSelectedVideoInfo, sWebPage: string;
Result := '';
sWebPage := WmsDownloadURL('http://www.youtube.com/watch?v=' + aVideoID + '&feature=youtube_gdata');
This bold part uses a YouTube URL, do you think that might be causing some problem, as the videos will be on PBS not on YouTube?
Result := '';
In this feed few pages with video, pages that work - with video on Youtube (original or copy - I don't know)tech.whiz wrote:Thanks Eugene. TED is now working for me, thank you for your quick help.
Result := '';
Podcast list from Ted is working great! Thanks guys!
