I am just testing Wild Media Server - Fantastic program!
I can watch my picture, listen to music and watch most of my movies. But I have a problem with recording from Elegato EyeTV3. The file extensien of the recordings is *.mpg
I have used GSpot to find out what type of file i am dealing with. Container: File Type: MPEG-2 Transport Stream, Mime Type: video/mp2t. I have tryed a lot of combinations but without luck
Can anybody help??
Thanks on before hand!
Sony Bravia KDL32v5500 - WMS - Recordings from Eyetv 3
Re: Sony Bravia KDL32v5500 - WMS - Recordings from Eyetv 3
Tried to rename the ts, m2ts and play via USB ?hansjor wrote: I can watch my picture, listen to music and watch most of my movies. But I have a problem with recording from Elegato EyeTV3. The file extensien of the recordings is *.mpg
Can anybody help??
Hello.
I have just tried to copy a recording from EyeTV3 to a USB stick. I am not able to play the *.mpg file.
Kind regeards
Kind regeards
Playing through a folder Transcoding works?
Mpg is not very suitable extension for MPEG Transport Stream, try ts or m2ts.hansjor wrote: I have just tried to copy a recording from EyeTV3 to a USB stick. I am not able to play the *.mpg file.
It seems selecting on the Sony Bravia menu: Movies, Transcoding, Watch Folders - and then the recorded file (still with the *.mpg extension works! I will give it a go whit new recordings.
Thanks very much!
Sorry to say - it worked two times - and then it stopped working - now i am getting the message: Ther is now connection to the server - but there is other movies play OK
Thanks very much!
Hello again.
Still driving me crazy! Some time it works - other times nope!
Can anyone give some help?
At the same files or different ? Right-click in the list of films you can perform a test transcoding.hansjor wrote:Hello again.
Hello again.
It is the same file. Some times it works. I have made a test transcoding and when it is not working i am getting the following result og the test:
C:\Windows>"C:\Program Files\Wild Media Server\wmsmpeg.exe" -i "\\QNAP219P\Qmult
imedia\RecordedTV\EyeTV Archive\Felthospitalet.eyetv\00000000113470a4.mpg" -f dv
d -vcodec mpeg2video -b 8000000 -aspect 16:9 -copyts -pix_fmt yuv420p -s 1024x5
76 -threads 2 -acodec ac3 -ab 448000 -ar 48000 -map 0:0 -map 0:1 "C:\Users\hansj
or\AppData\Local\Wild Media Server\WMS\Temp\Test_39ea80e8a71c5dc49b3d7eae418dee4
d.mpg" -v -1
FFmpeg version SVN-r20212, Copyright (c) 2000-2009 Fabrice Bellard, et al.
built on Dec 19 2009 00:45:55 with gcc 4.2.4 [Sherpya]
libavutil 50. 3. 0 / 50. 3. 0
libavcodec 52.37. 0 / 52.37. 0
libavformat 52.39. 0 / 52.39. 0
libswscale 0. 7. 1 / 0. 7. 1
[mpeg2video @ 0x123d350]ac-tex damaged at 9 30
[mpeg2video @ 0x123d350]Warning MVs not available
[mpeg2video @ 0x123d350]concealing 264 DC, 264 AC, 264 MV errors
[mpegts @ 0x3d9e30]max_analyze_duration reached
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1)
-> 25.00 (25/1)
Input #0, mpegts, from '\\QNAP219P\Qmultimedia\RecordedTV\EyeTV Archive\Felthosp
italet.eyetv\00000000113470a4.mpg':
Duration: 01:43:19.60, start: 39515.042367, bitrate: 2228 kb/s
Program 81 OAD MUX1
Program 101 DR1
Program 102 DR2
Program 111 DR Synstolkning
Program 211 TV 2 / Nord
Stream #0.0[0x83f]: Video: mpeg2video, yuv420p, 704x576 [PAR 16:11 DAR 16:9]
, 15000 kb/s, 25 tbr, 90k tbn, 50 tbc
Stream #0.1[0x849](dan): Audio: mp2, 48000 Hz, 2 channels, s16, 256 kb/s
Stream #0.2[0x853]: Data: 0x0006
Stream #0.3[0x857](dan): Subtitle: dvbsub
Stream #0.4[0x858](dan): Subtitle: dvbsub
Program 411 Nord
File 'C:\Users\hansjor\AppData\Local\Wild Media Server\WMS\Temp\Test_39ea80e8a71
c5dc49b3d7eae418dee4d.mpg' already exists. Overwrite ? [y/N] y
[ac3 @ 0x123f4b0]No channel layout specified. The encoder will guess the layout,
but it might be incorrect.
Output #0, dvd, to 'C:\Users\hansjor\AppData\Local\Wild Media Server\WMS\Temp\Te
st_39ea80e8a71c5dc49b3d7eae418dee4d.mpg':
Stream #0.0: Video: mpeg2video, yuv420p, 1024x576 [PAR 1:1 DAR 16:9], q=2-31
, 8000 kb/s, 90k tbn, 25 tbc
Stream #0.1(dan): Audio: ac3, 48000 Hz, stereo, s16, 448 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
[mp2 @ 0x123da50]Header missing
[mpeg2video @ 0x123d350]ac-tex damaged at 15 28
[mpeg2video @ 0x123d350]ac-tex damaged at 0 23
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 24
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 25
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 26
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 27
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 28
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 29
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 30
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 31
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 32
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 33
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 34
[mpeg2video @ 0x123d350]invalid mb type in I Frame at 0 35
[mpeg2video @ 0x123d350]concealing 572 DC, 572 AC, 572 MV errors
d.mpg" -v -1
-> 25.00 (25/1)
Program 81 OAD MUX1
Program 101 DR1
Program 102 DR2
Program 411 Nord
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Anybody - any idea??
A folder transcoding you can choose to view is not from the beginning. Settings intervals - Settings - Media - Resources - Service. Reportedly, the problem with the recorded stream. You can also try a different profile transcoding MEncoder (download page Settings-Transcoder-Profiles).hansjor wrote:Anybody - any idea??
