Since it is running on your vista workstation, it would be that address.
Can your see server per (http://server_ip_address:server_port) from another machine, not the vista machine.
You might have to set a static port. per attachment
Guess I should have added, if setup like the pic, http://192.168.xxx.xxx:9000
This shouldn't be this hard
Re: This shouldn't be this hard
- Capture.JPG (48.87 KiB) Viewed 8904 times
1x WDTV Live (FW 1.01.24)
1x O!Play HDP-R1 FW 1.18N
2x SMCWAA-G EZ Stream (never updated)
1x Dlink DSM-520 Media Lounge (FW 1.06 ,replaced by the WDTV Live)
In any case, what version of the program? (http://www.wildmediaserver.com/forum/vi ... p=314#p314)
I tried installing Wild, and initially I forgot to open a port in my router. It didn't work, obviously. Once I set up Port Forwarding in my Router through Port 4900 to the IP of my PC running WMS, all was OK.
- Jeff Schallenberg
Mont Saint-Hilaire, Québec
- Jeff Schallenberg
